Activity › Forums › Adobe Premiere Pro › can u change the ‘tape name’ of a clip once it has been captured?
Posted by Justin Tan on January 19, 2006 at 10:08 amAn EDL I have been given has 001 for the entire TAPE NAME – not good – is there any way to change the tape name in adobe premier?
thanks
Wil Renczes replied 20 years, 8 months ago 4 Members · 5 Replies -
Jacob Rosenberg
January 19, 2006 at 4:47 pmI believe when you first import the EDL and the files are offline, you can double click on them and change the meta data.
jacob
http://www.premiereprotraining.com
http://www.formikafilms.com
http://www.d2gfilm.com -
Doug Jacobson
January 19, 2006 at 9:56 pmYou should be able to open the .edl file in a text editor and then use find and replace to rename the tape. I tested with this in notepad and it worked fine.
Good Luck,
DougDoug Jacobson
Steamboat Productions -
Justin Tan
January 20, 2006 at 2:06 amthx for the response, I know I can fix it in notepad, but unfortunately there are heaps of clips all over the place and i would prefer not to do it this way…
just a little BG…
I am on FCP5.04 and the file made for me is from premier 6.5… having heaps of issues.. Have just found out i can change the reels via FCP so that’s all good now…..
anyone had experience with importing premier 6.5 into FCP?
Doug Jacobson
January 20, 2006 at 6:12 amCan you “replace all” in notepad to fix all occurances in one shot?
Doug
Wil Renczes
January 25, 2006 at 9:14 pmFYI, within Premiere, you can change the reel name – under the File menu, choose the ‘Timecode…’ entry after selecting a clip in the project window.
(Unfortunately, there’s no way to select multiple clips and change them all with this dialog in one shot. Sounds like a good feature request…)
