Activity › Forums › Apple Final Cut Pro Legacy › can two editors work on same project – simply?
Jeremy Garchow replied 17 years, 8 months ago 6 Members · 12 Replies
Andreas Kiel
January 25, 2009 at 3:12 pmCaleb,
You don’t need mirrored drives.
The thing the app does is not looking for files on the machine (like FCP) but for folders with contain the files. This makes sense as long you move folders from one machine or drive to another.
With the application you can save folder paths as well – so “returning mismatches” are resolved without user interaction.
We do use it in an environment where several people have to work with the same material on different locations and machines – pocket drives are send around, the material is copied to a local drive and the pocket drive will be send back.
The local paths are totally different, the guys who create the stuff have stored the clips on internal drives, at my place all the stuff goes to a small RAID into the customers folder, at the customers place everything is stored on a XSAN in a project folder.Andreas
Spherico
https://www.spherico.com/filmtools -
Jeremy Garchow
January 25, 2009 at 6:25 pmWhen Shane says exact, he means exact, from your local drives to your external drives. same user name, same directories, everything.
Although, XMLReconnect looks pretty cool.
Jeremy
