Activity Forums Zaxwerks Can This Tracking Be Done With Invigorator and AE?
  • Can This Tracking Be Done With Invigorator and AE?
    Posted by Harry Kramer on February 26, 2010 at 10:39 pm
    Or is it called “match / move”? Either way, can something like this be done? Thanks.
    Edward Wu replied 16 years, 7 months ago 2 Members · 1 Reply
  • Edward Wu
    February 26, 2010 at 11:52 pm
    Hi Harry,
    3D Invigorator does have a tracking command that allows you to track any After Effects 3D Layer. After you set up tracking, the 3D Invigorator object will then move along with the 3D layer.
    In the example you’ve provided, if you can obtain the camera data, it would be easier to set up because you can setup the 3D Invigorator Text to use the Comp Camera, and the text will change in perspective according to the camera changes.
    Best,
    Edward
