Activity Forums Apple Final Cut Pro Legacy Can the matte be removed from a greenscreen before export?
  • Can the matte be removed from a greenscreen before export?
    Posted by Christopher Comrie on May 29, 2009 at 8:06 pm
    I have a client for whom I have shot a greenscreen clip of an annoucer. I successfully removed the background, but I need to export it in such a way that his web tech guy can put it on the splash page of their website so that it looks as if the announcer is strolling out onto the page.
    I have done simple composite shots myself in FCP 6 using FCP’s Chroma Keyer plugin, but I put in the desired background myself. In this case, I’ve been asked to produce a simple .avi clip without a background. Is that even possible? That is, can one export a video file that is just a figure with no background whatsoever, or will the web guy have to do a composite with his background?
    Stephen Smith replied 17 years, 2 months ago 3 Members · 6 Replies
  • Tom Wolsky
    May 29, 2009 at 8:12 pm
    Do not render the keyed clip and export using the Animation codec with colors set to millions+. Take it to your compression program to resize and encode to whatever codec the web tech guy specifies.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
  • Christopher Comrie
    May 29, 2009 at 8:29 pm
    Would that be the Animation codec in Compressor? I don’t seem to see such a codec in FCP itself. Thanks.
  • Stephen Smith
    May 29, 2009 at 8:41 pm
    We do these web videos all the time. It sounds like they are going to build this in Flash. Flash recognizes the alpha channel.
    [Tom] Take it to your compression program to resize and encode to whatever codec the web tech guy specifies.
    They will most likely want it uncompressed. Flash will compress the footage with the background when the web guy is done with it. We just give it to them as an Animation – millions +. Hope this helps.
    Lone Peak Productions
    Check out my DVD Money Making Graphics & Effects for Final Cut Studio 2
  • Stephen Smith
    May 29, 2009 at 8:44 pm
    [Christopher] Would that be the Animation codec in Compressor? I don’t seem to see such a codec in FCP itself. Thanks.
    It is a Quick Time movie.
    File, Export, Using Quick Time conversion
    Set the Format to Quicktime and the Options to Animation
    June 9, 2009 at 5:26 pm
    Thanks! That did the trick.
  • Stephen Smith
    June 9, 2009 at 5:44 pm
    That is great to hear. I’m happy it worked out.
