Activity Forums AJA Video Systems Can the KiPro be used as a TC accurate playout device?
  • Can the KiPro be used as a TC accurate playout device?
    Posted by Pasquale Tropea on December 7, 2010 at 12:14 am
    Is it possible to use the KiPro as a playout device. Here’s the scenario we currently playout our final online ProResHQ sequences to HDCAM SR via the Kona 3, but sometimes, due to numerous factors these playouts suffer ‘dropped frames’ and require a fresh start or an assemble edit, regardless it’s painful and wastes lots of precious time
    Can the KiPro be used as a playout device? We’d copy the final exported ProResHQ to the HDD. Can you lock TC together with an SR deck? Can it punch in and be frame accurate?
    Pasquale
    Pat Mcgillen replied 15 years, 8 months ago 4 Members · 6 Replies
  • Jeremy Garchow
    December 7, 2010 at 4:41 pm
    [Pasquale Tropea] “Can the KiPro be used as a playout device?”
    Sure, but it’d have to be a crash record to the SR in single link 422. You can send LTC out to LTC in of SR.
    [Pasquale Tropea] “Can it punch in and be frame accurate?”
    As in insert edit? No. It would be, start the KiPro playback, hit record on the SR set to steal external ltc. I don’t know how interesting that is to you, but the KiPro won’t control the SR deck via rs422 if that’s what you’re asking.
    Jeremy
  • Pasquale Tropea
    December 9, 2010 at 7:11 pm
    Ideally the KiPro controls the SR Deck and synced playback/record occur. i understand that you can crash record but as long as the LTC is frame accurate, i.e. program start is at exactly 10:00:00:00
    does AJA envisage creating a simple web GUI that could initiate the control of the SR Deck. The KiPro has an ether port with RS422 and a simple laptop could be used to layoff frame accurate playouts
    /pasquale
    Pasquale Tropea
    Production Workflow Consultant
    BBC Media Center – White City
    Production Village – MC3 B1
    Support Partners (UK) Limited
    Shepherds Building F2
    Rockley Road
    London W14 0DA
    UK Mobile: +44 7525 123 473
    Tel UK DDI: +44 208 008 4921
    Tel UK Main: +44 207 043 8206
    Tel UK Fax: +44 207 043 8205
    http://www.support-partners.com
    pasquale.tropea@support-partners.com
  • Jeremy Garchow
    December 10, 2010 at 5:09 pm
    [Pasquale Tropea] “Ideally the KiPro controls the SR Deck and synced playback/record occur.”
    It won’t do that currently. Not sure if it ever will.
  • John Heagy
    December 11, 2010 at 4:33 am
    Correct, the KiPro will not control, but the SR deck can. The SR deck can control the KiPro via 422 and accurately edit to it’s self. There are many SR models. I don’t know if all of them have this feature.
    John Heagy
  • Pasquale Tropea
    December 21, 2010 at 10:25 pm
    We’ve got 2 SRW5800s… where can i find more info on the RS422 control abilities of the sony decks?
    thanks,
    pasquale
    Pasquale Tropea
    Rockley Road
    London W14 0DA
  • Pat Mcgillen
    January 2, 2011 at 5:00 am
    As far as a playout machine, I currently use multiple KiPro’s controlled via RS422 by Showplay software for multi- screen and edge blend content with Barco Encore systems, as well as for time-synced playout for symphony conductors timing marks video to keep in sync with movie content.
