Activity Forums Sony Cameras Can the EX1 do this?
  • Can the EX1 do this?
    Posted by Arnljot Bringedal on November 17, 2008 at 7:31 pm
    found this in the cow Indie-forum :
    “I very frequently plug the Shure SM 89 into the Panasonic AG-HVX200, and I plug the mic into channel 2, and I set channel 1 to record channel 2. One dial handles channel 1 and one dial handles channel 2, so I set channel 1 relatively low and channel 2 relatively high. This way I’ve covered the whole dynamic range. If someone starts to whisper, they’re on channel 2, if someone starts to yell, they’re on channel 1. ”
    Can I do this with the ex1? Cant seem to find the settings…..
    *** Norwegian videojournalist & Editor***
    Klaas Van urk replied 17 years, 10 months ago 3 Members · 2 Replies
  • Craig Seeman
    November 17, 2008 at 7:53 pm
    Easy. Plug Mic into channel 1 and set it to go to both channels. That’s set in the Audio menu.
  • Klaas Van urk
    November 17, 2008 at 8:11 pm
    Yes you can…
    First flip the switches from both channel 1 and 2 to manual and external.
    Then press the menu button and go to the bottom of the audio input menu.
    Choose EXT CH Select: CH-1
    By doing this mic input 1 is directed to both channels.
    Now you can perform your trick.
    Note: If the switches for both channel 1 and 2 are not switched to manual and external, the menu options are grayed out.
