Activity › Forums › Panasonic Cameras › Can the Citidisk HD store 1080 24P?
  • Mark Maness
    August 31, 2006 at 7:10 pm
    Well…… Let me warn you. The Citidisk is not quite there just yet. At the moment, it cannot directly record any HD until the next firmware revision. But here’s the way around it. Use your P2 cards to record as normal and dump them to the Citidisk drive until you almost fill it up, then you can dump it to you computer. Its a real pain, but it is useable (barely). It takes time but it is effective if you already purchased this drive.
    Personally, I would say if you can afford it, purchase the Firestore drive. It does work (mostly).
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
