Activity › Forums › AJA Video Systems › Can the AJA be plugged into a computer while recording from a camera?
  • Can the AJA be plugged into a computer while recording from a camera?
    Posted by Brenna Perez on September 9, 2013 at 3:31 am
    Hey guys, trying to figure out a VTR solution. I need to have immediate reverse playback for something being shot on Alexa. As far as I see, no external recorders playback in reverse unless it’s sped up. I need realtime backwards playback.
    My best bet, as I see it, is running an external recorder that records every time the camera does. If it can be plugged into the computer simultaneously, via FireWire, that would be ideal, so I could bring each file onto the computer as it appeared, then run it backwards from there.
    Would the AJA allow me to do this? I can’t find any information online. If not, are there any other solutions you know of?
    Many thanks!
    Brenna Perez replied 13 years ago 2 Members · 2 Replies
  • Kenyon Blower
    September 9, 2013 at 5:23 am
    You could use a remote control on the KiPro like a DNF. It should be able to control the KiPro & play -100% speed
  • Brenna Perez
    September 9, 2013 at 5:26 am
    But will it allow me to play it at real speed in reverse?
