Activity › Forums › Zaxwerks › Can TextBlocks be indivually animated in 3d Invig Pro 4.0
  • Can TextBlocks be indivually animated in 3d Invig Pro 4.0
    Posted by Subspecies on April 5, 2005 at 6:46 pm
    Hi all,
    if u key in your type in 3D Invig Pro, is it then possible to animate each letter individually?
    when i click on the letters individually and then set their “layer set”, it will change them all.
    I guuess my quesiton is, can “TextBlocks” be individuall animated like they are in ProAnimator?
    thx
    Matt Rhodes replied 21 years, 6 months ago 2 Members · 1 Reply
  • Matt Rhodes
    April 5, 2005 at 8:31 pm
    Hi Dante.
    Animation in 3D Invig Pro is done by Sets, as you know.
    To place each letter in a separate group, you’ll need to select each letter individually.
    To select an individual letter in a Text Block, do the following:
    – Make sure none of the letters are selected
    – Holding the Shift key, click on a letter
    – Still holding the Shift key, click on additional letters as necessary
    – Select the Set number for the selected letters.
    Let me know if you have other questions.
    Matt Rhodes
    Zaxwerks, Inc.
