Activity Forums Apple Motion Can text attributes be copied and pasted?
  • Can text attributes be copied and pasted?
    Posted by Larry Watts on November 9, 2011 at 4:22 pm
    I’m working in motion 4.
    I have quite a few layers of text added and applied a series of outline, drop shadow, opacity, and blur settings. I’d like to copy those attributes and paste them onto the other text layers. Can this be done?
    (photoshop does this)
    Also, can you save these attributes into a saved effect to apply now or later?
    If you can’t, what is a good way to be able to create a color value for one text layer and match it when working with another text layer?
    Larry
    Larry Watts replied 14 years, 10 months ago 2 Members · 2 Replies
  • Mark Spencer
    November 9, 2011 at 4:40 pm
    Yes, you can absolutely save your text formatting, style, or both. In the Text Inspector, in the Style pane, click the presets pop-up menu – from there you can choose what you want to save.
    Your new style will be available in this list, and also available in the Library in the Text Styles categories, from where you can simply drag it onto your text layer in the Canvas.
    Alternatively, you can drag your styled text layer from the Layers list to the Favorites folder in the Library, which will save the entire text layer. You can then add the full layer to any project.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Larry Watts
    November 9, 2011 at 5:53 pm
    Thanks Mark! I’m glad I asked. I thought it should be there, but an associate said it could not be done so I never posted this until now.
    Very nice!
    Larry
