Activity › Forums › Adobe Premiere Pro › Can someone tell me why this is happening?
  • Can someone tell me why this is happening?
    Posted by Jim Rogalski on April 15, 2014 at 6:31 pm
    Hi folks,
    In the timeline of my Premiere Pro sequence I am occasionally getting a single frame that has this distortion on it. The sequence setting is AVCHD 720P 29.97 frames per second. I’ve applied a fast color corrector as well as a lighting effect. Even after rendering-all this glitch will appear several times within the sequence and remains after output.
    Any ideas of why it’s happening and how to fix it will be greatly appreciated.
    Tim Kolb replied 12 years, 5 months ago 2 Members · 3 Replies
  • Tim Kolb
    April 15, 2014 at 10:40 pm
    It looks like the lighting effect to me.
    If you pull it off, does the problem go away?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Jim Rogalski
    April 16, 2014 at 12:45 pm
    Hi Tim,
    Thanks for the reply. The problem does go away when I turn off the lighting effect. I’ll have to work on another way to get the subject better lit. Cheers, Jim.
  • Tim Kolb
    April 16, 2014 at 2:10 pm
    I think that old Photoshop lighting effect has been neglected (and should probably just be deleted) for some time.
    Most people might use color correction to change contrast or key/fill ratios to some degree, but there really is no practical substitute for just lighting it correctly when you shoot it…
    TimK,
    Kolb Productions,
