Activity Forums VEGAS Pro can someone please help a newbie ?
  • can someone please help a newbie ?
    Posted by Cosmoman on January 31, 2006 at 9:13 pm
    Hello to all. I have had Vegas 6 for about half an hour, and am in the process
    of figuring it all out. I have two questions.
    1) I have done a title scroll-upwards from the bottom. The part where the text
    disappears is just under the top of the screen. How do you get the text to
    disappear right at the very top of screen ? I am using PAL ( in Australia )
    with a screen size of 720 x 576.
    2) How do you make the preview screen a little larger than its default size ?
    I don’t necessarily want it ” project-size ” but just a little larger than
    default size ?
    Thank you so much, anyone , for helping.
    Best regards to all, from Oz.
    Doug Graham replied 20 years, 7 months ago 3 Members · 3 Replies
  • Edward Troxel
    January 31, 2006 at 10:01 pm
    [cosmoman] “1) I have done a title scroll-upwards from the bottom. The part where the text
    with a screen size of 720 x 576.”
    At the top of the generated media box, make sure the “size” is correct.
    [cosmoman] “2) How do you make the preview screen a little larger than its default size ?
    default size ?”
    You have to use one of the preset sizes.
    Edward Troxel
    JETDV Scripts
  • Cosmoman
    January 31, 2006 at 11:35 pm
    Thank you so much, kind people. You have indeed helped me.
  • Doug Graham
    February 1, 2006 at 10:22 pm
    Ed is right about the pre-set sizes, but you don’t have to accept the default. You can drag the monitor window to resize it, and as the window becomes large enough to accommodate the next bigger pre-set video window, it will enlarge.
    Regards,
    Doug Graham
