Activity Forums Audio Can someone please clarify ADAT ports?
  • Can someone please clarify ADAT ports?
    Posted by Graeme Hague on January 8, 2010 at 3:58 am
    This could be silly I know, but I have always assumed that ADAT optical I/O’s such as you’ll find on the Behringer ADA8000 must be connected to an ADAT product of some kind- at least at one end.
    Suddenly I might have seen the light… so any two devices with an ADAT optical I/O will “see” each other and connect? Neither has to be an ADAT product? “ADAT” is like a protocol or a format?
    So what’s the difference between the Optical I/O on my M-Audio FW410 and the ADAT Optical I/O on the ADA8000? Is there a difference? I’m going to guess one carries only 2 channels while the ADAT Optical is specifically designed to carry 8 channels. Are they inter-connectable (yes, I just invented that word)?
    Cheers, Bag.
    Graeme Hague replied 16 years, 8 months ago 3 Members · 3 Replies
  • Ty Ford
    January 8, 2010 at 1:27 pm
    Hello Bags and welcome to the Cow Audio Forum.
    The optical port on apiece of gear may be ADAT, S/PDIF or both, depending upon how it was designed.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Richard Crowley
    January 8, 2010 at 4:14 pm
    The optical interconnect you are referring to was originally designed for the “TOSLINK” low-cost 2-channel interconnect by Toshiba for consumer stereo equipment.
    The same connector and fiber “cable” was re-purposed by Alesis for their unrelated 8-channel protocol. The ADAT interconnection system was originally proprietary to Alesis equipment, but has become a rather open standard used by others who make 8-channel audio equipment.
    You are correct that is it quite possible that an “ADAT” cable configuration won’t necessarily have Alesis-brand equipment at either end.
  • Graeme Hague
    January 9, 2010 at 12:31 am
    Thanks guys, it puts a slightly different slant on my audio interface shopping list. Cheers!
    Graeme Hague
    Author/Composer
    Freelance Audio Engineer
