Activity Forums Adobe After Effects Expressions Can someone explain how the wiggle expression parameters work?
  • Can someone explain how the wiggle expression parameters work?
    Posted by Tom Carter on May 10, 2006 at 7:41 pm
    I’m trying to use the wiggle expression to change the opacity of an image in my comp. I want the opacity centered around 50% and for it to wiggle from anything from 0% to 100%.
    At the moment the opacity of the layer is set to 50%, so my expression looks like:
    wiggle(4, amp)
    The question is, will the ‘amp’ setting wiggle above and below 50% by amount you set, or is that the total range of the wiggle (in other words half above and half below)?
    i.e. do I need an amp of 50 (giving me 50 above and below 50%), or do I need an amp of 100 to get the range I need?
    Thanks for looking and I hope this makes sense…
    Tom
    http://www.crate20.co.uk
    Tom Carter replied 20 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 10, 2006 at 9:11 pm
    It will wiggle around the static or keyframed value of the parameter. If you have opacity set to 50% and use the expression wiggle(4,50) you’ll get what you’re after. Open the expression graph and you’ll see what’s happening.
    Dan
  • Tom Carter
    May 11, 2006 at 12:57 am
    Brilliant. Thanks.
