Activity Forums Apple Final Cut Pro Can someone confirm or deny a bug?
  • Can someone confirm or deny a bug?
    Posted by Jeremy Garchow on January 22, 2014 at 11:51 pm
    EQ an audio clip under the “Audio Enhancements” > Equalization > EQ ‘button’
    Now close the EQ floating window. EQ holds.
    Now click the same EQ button, EQ is now flat?
    Anyone else?
    Jeremy
    Jeremy Garchow replied 12 years, 8 months ago 3 Members · 4 Replies
  • Nick Toth
    January 23, 2014 at 12:14 am
    Same here. I have reported it to Apple.
    anickt
  • Jeremy Garchow
    January 23, 2014 at 7:48 pm
    Thanks, Nick!
  • Chris Fenwick
    January 25, 2014 at 3:46 pm
    I thought I was going crazy but yes, I’ve seen the same EQ problem… if you just trust the eq is there, and don’t go into to double check it… it’ll hold its setting… but yes, is is clearly wrong.
    I suspect a 10.1.2 very soon.
    Chris Fenwick
    Director/Editor
    SLCE Editorial
    Oakland, CA
  • Jeremy Garchow
    January 25, 2014 at 6:54 pm
    [Chris Fenwick] “I thought I was going crazy but yes, I’ve seen the same EQ problem… if you just trust the eq is there, and don’t go into to double check it… it’ll hold its setting… but yes, is is clearly wrong.”
    That describes it perfectly. Thanks, Chris.
