Activity › Forums › Adobe Premiere Pro › Can Smoke Read EDLS from Premier 6.5????
  • Can Smoke Read EDLS from Premier 6.5????
    Posted by Carlos Montemayor on August 31, 2005 at 3:05 pm
    I have a project where I’m going to do the offline in premier 6.5. I wanto to know if I export the EDLS from premier, will Smoke read them, so the online will be faster in the smoke.
    Carlos Montemayor replied 21 years ago 2 Members · 2 Replies
  • Sameer Shrivastava
    August 31, 2005 at 3:28 pm
    yes, it can read, dont render any thing on time line. dissolves and associted clips may be a problem. good option is to take without dissolves or wipes
    or just open the printed edl and see if it shows time code from your tapes or aux timecodes starting in range from 00:00:00:00. it should show timecodes from your tapes only. aux timecodes are not upgradeble.
    cut only edl is safe bet
  • Carlos Montemayor
    September 1, 2005 at 3:15 pm
    I will keep in mind your advice.
