Activity Forums DaVinci Resolve can Resolve for Mac run on multiple GPU’s?
  • can Resolve for Mac run on multiple GPU’s?
    Posted by Mika Joon on May 11, 2010 at 2:47 am
    Hello DaVinci Friends
    Just wondering if Resolve for Mac will support multiple NVIDIA GPUs for acceleration,
    Can you use a GPU-Xpander Pro 2 with 2 GTX 285 cards inside running externally.
    it would be great solution for performance.
    Thanks in advance
    Sascha Haber replied 16 years, 3 months ago 4 Members · 5 Replies
  • Jamie Allan
    May 11, 2010 at 5:35 pm
    Unfortunately, due to limitations on the current Mac hardware & OS there’s no multiple GPU config possible.
    No idea if this’ll ever change as traditionally Apple have never mentioned it might change. They’d need to add more PCIe 16x slots as currently, if you had 2 x double size GPU cards you couldnt add Fibre/SAS for storage or IO cards….
    Jigsaw Systems Ltd. – IT & Broadcast specialists for the UK
    https://www.jigsaw24.com
    https://www.jigsawbroadcast.com
  • Sascha Haber
    May 26, 2010 at 4:11 pm
    And what happens if you connect a Quadro Plex ?
  • Mika Joon
    May 28, 2010 at 10:42 pm
    Hi Sascha, I agree with you
    It would be good to find out from DaVinci or Black Magic if Resolve can support external multi GPU devices like the ones mentioned to accelerate processing .
    if possible or not, could someone respond please
    thanks in advance.
  • Peter Chamberlain
    June 2, 2010 at 4:50 am
    Hi all, we continue to review the GPU processing options available from third party hardware vendors, which to date none provide a significant advantage to our working configurations. There are driver, operating system, power and bandwidth limitations on and off the motherboard PCIs buss and limits to slot count and the bandwidth needed on each of those slots. Adding extra slots via an external box does not necessarily increase bandwidth and extra cards off-board need low latency access too. Keep in mind we have developed and tuned Resolve to perform multiple nodes/layers of grading in real time with 4:4:4 HD resolution files on the Mac. Given we have shown we can do this, and will start shipping soon, if there was some other solution that would speed this up, to give you more power, we are pretty sure we could make that work too. We just have not seen anything so far to help us and you in this area.
    Let’s see what Apple release in the new MacPro and remember, new GPU’s from Nvidia are always in development.
  • Sascha Haber
    June 8, 2010 at 9:30 pm
    No new Mac Pros…
    Will it run on the iPhone 4 ?
