Activity Forums Adobe After Effects can rendered 3D text be animated with presets in AE
  • can rendered 3D text be animated with presets in AE
    Posted by Jason Barton on October 9, 2012 at 12:43 pm
    this is a AE CS6 questions that starts with Photoshop.
    I’m following a tutorial from Adobe’s magazine, photoshop dimensions (https://www.photoshopdimensions.com/)…….and i have a question.
    Using the adobe creative cloud apps, software is up to date.
    I’m following the tutorial in that report for the “3D Text” and would like to use that text in after effects and add an animated preset to the text.
    It’s just shows you how to create 3D text in photoshop, nothing out of the ordinary.
    Would the animated presets for text in AE work correctly with the “3D Text” allowing each letter of the 3D Text to be animated or will it act like a image and only animate the entire text block?
    is the 3D text i create still “Text” that each character in a word can be animated seperately?
    thanks for any clarification
    Roland R. kahlenberg replied 13 years, 11 months ago 4 Members · 6 Replies
  • John Cuevas
    October 9, 2012 at 12:56 pm
    No, you will lose the 3D in AE.
    AE CS6 can create and extrude text though with ray tracing. Over at Adobe.com there are quite a few FREE TUTORIALS for using this new ability.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jason Barton
    October 9, 2012 at 1:48 pm
    thanks
  • Roland R. kahlenberg
    October 9, 2012 at 4:32 pm
    With CS6, you can extrude text with the Text Tool. You can mix and match Text Animation Presets as you were able to do with earlier versions. One caveat is that Text Presets that use the Blur Text Animator Property are not supported.
    One sweet thing with CS6 and raytraced text is that you can switch between the ray-tracing and classic 3D render engines without losing animations created with the Text Tool’s Animator Groups. This allows you to set up your animations quickly while having using Classic 3D Render engine. Then when you’re happy with the animation, you can switch to the Ray-traced engine and set up your beautiful 3D text to your heart’s content.
    Want to make adjustments to the animation? No problem, just switch to the CLassic 3D engine and work faster as you make your changes. Cool SH*T! 😉
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Tom Daigon
    October 9, 2012 at 5:47 pm
    Nice tip. Thanks Roland!
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Jason Barton
    October 9, 2012 at 7:12 pm
    thanks Roland
    October 10, 2012 at 1:28 am
    You’re most welcome guys!
    Cheers
    RoRK
