Activity Forums Boris FX Can RED5 masks stick?
  • Can RED5 masks stick?
    Posted by Jaeson Koszarsky on February 27, 2012 at 10:56 pm
    Using RED5 & Media100Suite2.1.
    I apply a custom shape mask to a layer. If I change the position/size/rotation/etc of the layer, the mask remains unaffected. I want the mask to stick but it remains unchanged.
    Same thing happens if I apply masks to containers. In RED4, I could use pre-comp containers but it doesn’t work the same in RED5.
    Is there a way to make the masks adopt changes that are applied to the layer? I don’t want to enter all the key-frame data multiple times. I’d rather be able to create and move a single object around.
    Boris Yamnitsky replied 14 years, 6 months ago 3 Members · 2 Replies
  • Peter Mcauley
    February 28, 2012 at 1:30 pm
    Hi Jaeson,
    You need to place the mask shape in the “face” mask track in order for it to do what you want.
    There are two mask tracks on every shape track, one is pre-transforms and one is post transforms. You’ve been placing the mask in the post transforms mask track so it ignores any transformation moves that have been applied to the track. Just drag the mask shape up into the other mask track and the mask will lock to the media.
    If this is unclear please let me know and I’ll offer a more in-depth explanation.
    Cheers,
    Peter.
  • Boris Yamnitsky
    February 28, 2012 at 2:08 pm
    OK, you discovered the difference between downstream and upstream masks. To make a mask stick to the layer even after transformations apply it “upstream”. To do that use the mask track nested in Face track. Let me know if this technique works for you.
    Boris Yamnitsky
    BorisFX
