Activity Forums Adobe Premiere Pro Can PP eliminate horizontal scan lines from a conversion?
  • Can PP eliminate horizontal scan lines from a conversion?
    Posted by Victor Osaka on September 27, 2016 at 1:18 am
    Not sure if I am seeing scanlines or something else. Video conversion to MP4 using 1080p YouTubeHD configuration. Getting these horizontal lines on faster moving objects in the video. What causes this and how do I get rid of them?
    Victor Osaka replied 9 years, 11 months ago 2 Members · 2 Replies
  • Shane Ross
    September 27, 2016 at 4:26 pm
    This is caused when you converted interlaced footage to Progressive, without deinterlacing it. That artifacting is “burned in.” Meaning that it’s baked into the clip…you can’t deinterlace it now. The only way to get rid of it is to convert it again, this time deinterlacing it when you convert, or before you convert. If you have this in your timeline and you export to YouTube..then you need to deinterlace it on your timeline, THEN export.
    Shane
    Little Frog Post
  • Victor Osaka
    September 28, 2016 at 3:27 am
    Thank you for the response. Much appreciated.
