Activity Forums Adobe After Effects Expressions Can Parented Camera “know” it is OFF?
  • Can Parented Camera “know” it is OFF?
    Posted by Shai Benshoshan on February 27, 2019 at 7:36 pm
    I have this camera nicely moving over a 3d surface between points, using Dan_E’s expression mainly.
    Is there any trick to use the rotation to “fix” the angle back to a safe margin?
    I know the way to to this is by figuring the distance between the camera’s position and point of interest
    and then using the angle to the ground as a bar.
    Help is appreciated ;
    Thanks;
    Shai
    Dan Ebbert’s Expressions:
    moveTime = 1.0;
    stopTime = 0.2;
    numberOfLayers = 11;
    segDur = moveTime+stopTime;
    idx = Math.floor(time/segDur)+1;
    phase = time%segDur;
    if (idx < numberOfLayers){
    P1 = thisComp.layer(idx).transform.position;
    P2 = thisComp.layer(idx+1).transform.position;
    ease(phase,0,moveTime,P1,P2);
    }else{
    thisComp.layer(numberOfLayers).transform.position;
    Kalleheikki Kannisto replied 7 years, 6 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    March 6, 2019 at 10:11 am
    Not sure I understand what you’re trying to achieve, but perhaps using a single-node camera (without the point of interest node) would avoid the rotation issue?
    Senior Graphic Designer
