Activity Forums Adobe After Effects Can paint layers be merged?
  • Can paint layers be merged?
    Posted by Cain Nuke on April 15, 2014 at 3:15 pm
    sorry if im not using the correct term and if my explanation is not clear enough. Please see the image below for a more graphic explanation.
    https://i.imgur.com/462Pln9.png?1
    you know that as you paint, you get a lot of these layer-like entries on the layer pane such as clone 12, eraser 30, etc.I would like to know if its possible to merge all of them in one since it would be much easier to handle that way.
    Thank you.
    View post on imgur.com
    Anthony Dupsta replied 12 years, 5 months ago 2 Members · 2 Replies
  • Cain Nuke
    April 15, 2014 at 6:37 pm
    Its just for the sake of simplicity. Lets say i use the eraser 1000 times, its gonna get very crowded down there so if i merge everything into one single thing it will be easier to handle.
  • Anthony Dupsta
    April 15, 2014 at 7:13 pm
    Hey Cain,
    No they can not be merged down. I agree that this would be a nice feature to flatten your stokes or bake them down in comp. My comps have gotten very heavy with hundreds of strokes in the past and it can get slow.
    Two similar solutions I can offer:
    One is to of-course bake that comp out, re-import, that will indeed merge them! 🙂
    However something you can try; make sure all your paint strokes are inside the same comp. Right click on that comp in the project window and and you can see that the comp, not footage, but comp, can become a proxy. So you can bake the comp down into an image sequence and than assign that heavy paint comp, with tons of strokes, into one image seq that you can toggle on and off for further modifications, much lighter but requires organization and media management. That is my suggestions.
