Activity › Forums › Panasonic Cameras › Can P2HD record SD by it’s internal recorder
  • Can P2HD record SD by it’s internal recorder
    Posted by Alex Desrial on April 20, 2010 at 9:52 am
    Dear All,
    Need your info if P2HD camera can record SD Video with it’s internal recorder ?
    Is the video clean or there is motion artifact ie interlacing problem introduced ?
    Thank you for your share info.
    Best Regards
    Alex Desrial
    Alex Desrial
    MediaIntegra – Jakarta
    Michael Sacci replied 16 years, 5 months ago 3 Members · 2 Replies
  • Emre Tufekci s.o.a.
    April 20, 2010 at 1:07 pm
    If you are refering HVX200 with an internal tape system:
    Yes: The tape will record SD only and will do it very nicely.
    Other P2 cameras with no tape system (including the HVX200) will record SD (DV or DVCPRO50) and will also do it very nicely.
    Hope this helps.
    Emre Tufekci
    http://www.productionpit.com
  • Michael Sacci
    April 20, 2010 at 8:57 pm
    Tape is only DV25 so it has all the limitations of DV, doesn’t like reds or bright blues, there is interlaced issues inherent to DV and 4:1:1. If you are looking for progressive, it records 24pA and FCP will remove the pulldown and give you clean progressive.
    But if you go to P2 and shoot DVCPro50 you will get much cleaner video. If is less compression and 4:2:2 color space. Twice the files size but worth it.
