Activity Forums Adobe After Effects Can Open .mov file in After Effects CS4
  • Can Open .mov file in After Effects CS4
    Posted by Ugo Amadi on January 27, 2012 at 3:56 am
    Hi All,
    I’m not sure why I can’t open a video file with the .MOV extension in AE CS4 as I keep getting an error message, but I was able to open same file in the much older AE 6.5 with its audio.
    Hope someone can help.
    Thanks.
    Ugo Amadi replied 14 years, 7 months ago 2 Members · 2 Replies
  • Ben G unguren
    January 27, 2012 at 6:35 am
    Have you tried the file in other apps? (QT player, MPEG Streamclip, etc)
    If you can open it in MPEG Streamclip, I’d just re-export it from there to a high-quality codec and try importing the new file instead. A bit of a workaround, but if it’s just one clip, this lets you keep moving.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Ugo Amadi
    January 29, 2012 at 8:31 pm
    Thanks for this tip. Actually, I donwnloaded it, but just keep getting errors running the software MPEG Streamclip. Actually, I’m trying to open and work with about 150 video clips, so it’s a lot of file conversions to be done. Actually, I was able to do the conversion to a mp4 format, but there was a lot of pixellation on the converted clips. But the files opens in AE Cs4 with Mac, but I’m more comfortable working with windows.
    I’ll appreciate more tips.
