Activity › Forums › Adobe After Effects › can only scrub audio in after effects
  • can only scrub audio in after effects
    Posted by Chad Goodwood on February 15, 2010 at 8:26 pm
    Hi all,
    Just having a small problem getting audio to play in AE. Here’s the score:
    1. I can import a sound file ie. WAV
    2. I run RAM preview using all the usual proceedures and can see the wave form and VU meter moving, but NO sound?
    3. But, if I scrub the audio I CAN hear it!…Bizarre?
    4. If I render an audio effect on it I can hear it!
    4. Audio is not muted
    5. Preferences/Preview/Audio is checked
    Any clues gratefully received!
    Cheers
    Michael Szalapski replied 16 years, 7 months ago 2 Members · 3 Replies
  • Michael Szalapski
    February 15, 2010 at 9:39 pm
    Did you check what audio output hardware device is mapped?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Chad Goodwood
    February 15, 2010 at 9:47 pm
    it just says the default device is “After effects windows sound” with no other options. When i go into settings my directsound output says “no audio device” and my directsound input says “Quattrus Wave In”. I don’t appear to be able to change these in anyway?
  • Michael Szalapski
    February 16, 2010 at 2:20 pm
    I’m a bit at a loss here, not every having had problems with my sound before.
    On the Output Mapping settings does it give you a right and a left?
    Hopefully, now that the holiday weekend is over, some others will be able to assist.
    – The Great Szalam
