Activity › Forums › Adobe Premiere Pro › Can only label clips in timeline if linked to audio??
  • Can only label clips in timeline if linked to audio??
    Posted by Jimmy Brunger on August 31, 2011 at 10:30 am
    Is there any reason why I can only change a clip’s colour in the timeline if it’s linked to an audio clip? As soon as I unlink I don’t get the right-click option to change video label colour…?
    Gibran Sirena replied 13 years ago 3 Members · 3 Replies
  • Jimmy Brunger
    September 2, 2011 at 10:49 am
    Seems I can only label in timeline if there is linked audio present. If I have clips with no audio I can’t colour them up – is this normal?
    Thanks.
  • Andrew Downie
    July 31, 2013 at 10:43 am
    I have the same problem but found a solution. Usually I just right-click on a clip to bring up the label options, but if there is no audio this doesn’t appear… instead you have to click the clip then go to the toolbar – edit>label to see the colour options.
  • Gibran Sirena
    September 12, 2013 at 1:55 am
    THANKS!!!
