Activity Forums Apple Final Cut Pro Legacy Can only hear audio when I fast-forward or rewind
  • Can only hear audio when I fast-forward or rewind
    Posted by Katie Fitch on February 11, 2008 at 11:49 pm
    I just started using FC and I just want to practice editing a scene. I imported an aiff file that I converted in Quicktime. I also tried to import a wav file that I also converted in Quicktime. Unfortunately, I can’t hear the audio playback unless I am fast-forwarding or scrubbing. I have rendered the file (maybe I did this incorrectly) but nothing has come of it. I have also changed the external video device to none. I would really appreciate any advice!
    Katie Fitch replied 18 years, 7 months ago 2 Members · 2 Replies
  • Kenyon Blower
    February 12, 2008 at 12:51 am
    are you converting before importing. If so, just import the aiff file directly. In the timeline, is there a red bar at the top. This means in needs rendering. On audio, you will here a series of beeps when you try to play it. Hope this helps
    Kenyon Blower
    Vide-Post / San Diego
    Dual 2.5 G5
    3 Gig Ram
    Medea 2TB Fibre Raid
    Medea 640 gig SCSI
    FCP 5.1
    KONA LH
  • Katie Fitch
    February 12, 2008 at 3:16 pm
    Thanks so much! It’s working now 🙂
