Activity Forums Boris FX Particle Illusion can not use avi-files for background image
  • can not use avi-files for background image
    Posted by Saudi on September 9, 2005 at 5:44 pm
    Hy Folks,
    I`ve got problems using avi-files as background image. It`s no problem to use a still image like a jpg. When I try to use a avi-file the background stays black. Does anybody have experiences with this problem. Are there any settings that I have to check, or do I have to use a special codec? I tried a standart Microsoft DV and Uncompressed File.
    Please help, otherwise I have to learn combustion within the next day. 🙂
    Thanks in advance
    Martin
    Saudi replied 21 years ago 2 Members · 4 Replies
  • Saudi
    September 9, 2005 at 6:14 pm
    Ok……i just deinstallde my blackmagic stuff and it worked. Dont know what that means!!!!
    What codecs are supported by PI? And why is it not possible to use Quicktime files in the Windows version?
    Greez Martin
  • Alan Lorence
    I suspect OpenGL is the culprit. First, open the pIllusion prefs and on the OpenGL page check the “do not use texture RAM for bg images” option. If that doesn’t help, then try running with software rendering instead of hardware acceleration. The easiest way to do this is from the Start – Programs – particleIllusion 3.0 menu on Windows, and by launching pI3 with the Shift key held on OS X.
    If the problem goes away when running with software rendering, then you need updated video drivers.
    Alan.
    wondertouch
  • Alan Lorence
    September 9, 2005 at 6:16 pm
    Don’t know anything about Blackmagic. The Windows version does not support QuickTime right now.
    Alan.
    wondertouch
  • Saudi
    September 9, 2005 at 7:06 pm
    Thanks for the fast reply, I will give it a try. 🙂
    Greets Martin
