Activity Forums Apple OS X Can not see FW800 drive on a windows network
  • Can not see FW800 drive on a windows network
    Posted by Kent Rich on February 22, 2007 at 5:29 pm
    I’ve got a MacBook Pro Intel core duo machine with a connected FW800 drive. I would like to move some files back and forth from my FW800 drive to my PC, but can’t seem to see the FW800 drive on the Windows network. Is there a configuration I’m missing?
    Sincere thanks,
    Kent Rich
    Shane Sokolosky replied 19 years, 2 months ago 3 Members · 2 Replies
  • Jeff Carpenter
    February 22, 2007 at 8:07 pm
    This is kind of a non-answer, but I’ll tell you what I do in situations like this.
    Being more adept at using a Mac I put my efforts into seeing the Windows machine I want on the Mac and then using the Mac to copy the files instead of using the Windows machine.
    I know…not a huge help, but turning the situation around like that has often allowed me to solve problems without actually fixing them!
  • Shane Sokolosky
    February 23, 2007 at 3:56 pm
    Is your firewire drive formated as an HFS+ volume? or did you format it as FAT32? If it’s FAT 32 it will show up on both OS X and Windows if it’s HFS + it will only show up on OS X, unless you use a utillity called mac drive.
    https://www.mediafour.com/products/macdrive6/
    Obviously if you have a place to transfer the data from your drive now, then format the drive as FAT32, then put the data back on the drive then you wouldn’t need this utility.
    Hope this helps,
    Shane Sokolosky
    Circuit Access
    Email – heysomthin@aol.com
    Phone – (714) 599-1611
