Activity › Forums › Adobe Premiere Pro › Can not reverse a sequence.
  • Can not reverse a sequence.
    Posted by Matt Kowalski on October 18, 2014 at 7:47 pm
    Hello,
    I’m having a problem with reversing sequence.
    It contains of few video clips. I’ve put this whole sequence into another one and tried to reverse the sequence. I selected Reverse Speed. As a result only audio plays when I preview it. There’s no video. Line is green so it shold be there but it’s not. What to do?
    Zlatan Sadiković replied 11 years, 2 months ago 2 Members · 1 Reply
  • Zlatan Sadiković
    July 2, 2015 at 9:21 pm
    Hi, I just now had the same problem, I think this is whats happening: you put clips into one sequence and then you put that sequence into another sequence, everything is fine for now, until you reverse the sequence, but you see black because premiere sequences aren’t just your clips, the BLACK NOTHINGNESS after the clips is also a part of the sequence, so what happened is your reversed sequence is showing you the endless darkens before it shows you your reversed clips
    the trick here is to NEST (select all clips and right click and select the nest option) the sequence you wish to reverse, this will create a nested sequence, just use that one as a clip and reverse and speed up as you wish ,
    worked for me 😀
