Activity › Forums › Apple Final Cut Pro Legacy › can not reconnect files with “.” (period) in,
Posted by Andreas Karoliussen on July 10, 2006 at 9:34 amHi,
My problem is reconnecting files, FCP won
Andreas Karoliussen replied 20 years, 2 months ago 3 Members · 6 Replies -
Walter Biscardi
July 10, 2006 at 11:20 am[Andreas Karoliussen] “Name in final cut: “cars under bridge. tilt cloud, airplane”
Name in Finder: “cars under bridge. tilt cloud, airplane”
Name in Reconnect window: “cars under bridge. tilt cloud – airplane tilt cloud – airplane.””Yep, I see the same thing here on some of my files, but FCP is able to reconnect to them just fine. I’m taking an Avid OMF and recapturing it in FCP and they always have something like “kitchen with pan to oven.tk1” and it will often show up as “oven-tk1” I’ve only seen this since I switched to FCP 5.1.1 so it may be something that’s due to the new file management structure implimented with this release.
But FCP seems to do just fine reconnecting properly to my clips as if it knows that it has changed the file name.
Walter Biscardi, Jr.
https://www.biscardicreative.com“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Walter Biscardi
July 10, 2006 at 11:51 am[Andreas Karoliussen] “my problem is that in the reconnect window FCP repeats the last part of the file name and therefore will not reconnect.”
Ok, that’s a different issue than what I’m seeing here. I’m not seeing any sort of duplication within the file names.
Harry
July 10, 2006 at 6:49 pmI found that when FCP gets recalcitrant about reconnecting to a particular file which I can see is there, I change the search from “Video” (default) to “ALL” and then select that file manually in the window. I had this problem 2 days ago and, when my panic subsided, this was the answer for me.
Best
Harry.
Andreas Karoliussen
July 11, 2006 at 6:49 amThank You for your suggestion Harry
When i try your solution it works fine,
but in my case its not a file now and then thats recalcitrant, its ap 5 – 7 hours of media in small clips. and this error affects approximately half…
