Activity › Forums › Apple Final Cut Pro Legacy › can not import XDCAM files to FCP
  • can not import XDCAM files to FCP
    Posted by Grant Barbeito on May 6, 2008 at 6:28 am
    I had a shoot over the weekend with an EX1. I backed up a copy of the files to a hard drive and the files showed in the XDCAM window so I know the files are good. Now that I am trying to import into FCP the back up of the files are not importing into FCP.
    The video files are MP4 files. Anyone had a problem importing files?
    I also need advice on how to transfer to .mov files from 720p to DV.
    Please. Project needs to be viewed ASAP.
    Andy Mees replied 18 years, 4 months ago 3 Members · 6 Replies
  • Andy Mees
    May 6, 2008 at 6:34 am
    did you back up the MP4’s only or the full BPAV folder structure of the SxS card? you need the folder structure of XDCAM Transfer won’t be able to work its magic
    by the way, topic’s tend to come up pretty regularly so for future reference, a quick search is often the fastest way to find the answer to many questions
  • Grant Barbeito
    May 6, 2008 at 7:39 am
    Hi There,
    Thanks for writing. I do not see the BPAV file attached to the files I backed up. I was able to see the files in the XDCAM browser but the few hundred files I have backed up do not open in the XDCAM transfer.
    Is there an easy way to re attach the BPAV file or a way I can convert them to QT files?
    The camera arrived the day before the shoot.
  • Rafael Amador
    May 6, 2008 at 10:05 am
    Hi Grant,
    Have a look to the “SONY CineAlta forum”. Craig Seeman has found a workaround for the people that likes to play with the .mp4.
    https://forums.creativecow.net/readpost/142/858308
    Mac OX 10.5.2-FC 6.02-QT 7.4.1
    G5 2x2Gh 4GbRAM-BlackMagic Extreme
    PMBP 17″Core2Duo 4GbRAM-AJA ioHD
    JVC DTV-17″
    SONY EX-1 . SONY PD170
    ..and always a big mess on top of the table.
  • Andy Mees
    May 6, 2008 at 12:57 pm
    [grant barbeito] “Thanks for writing. I do not see the BPAV file attached to the files I backed up”
    yikes .. painful way to learn the lesson, you gotta keep the folder structure intact in this brave new tapeless world.
    [grant barbeito] “Is there an easy way to re attach the BPAV file or a way I can convert them to QT files? “
    hopefully Craig’s/Rafael’s tip will get you out of trouble … another trick posted over at the Apple Discussions seems to be to substitute these clips source clips into a completely different but valid BPAV folder structure and simply make sure the substituted clips are renamed as for the clip they replace. haven’t tried this (not an EX guy) but it could be a pretty nifty solution if it works
    https://discussions.apple.com/thread.jspa?messageID=7128012&#7128012
    Best
    Andy
  • Rafael Amador
    May 6, 2008 at 1:26 pm
    Andy,
    Why some people is making so complicated to work with the EX-1?
    I think the workflow is really easy. Only archiving had make me think a bit more. I’m saving in 50GBs Blu-ray disks the converted .mov’s . You can download the rushes from the disk at some 9MB/s. Around half of RT for me is good enough.
    I also make a small h264 with all the rushes. That helps me to look for the images that I need.
    I use the “Spotlight Comments” in the Info window to put some keywords. Is like a cheap data-base, but works great.
    JVC DTV-17″
  • Andy Mees
    May 6, 2008 at 1:50 pm
    anyone making the mistake of backing up only the raw clips instead of the full folder structure is in pretty good company tho Rafael, seems to be an easy mistake with everyone and there brother doing it!
    I like your backup method, its good thinking and sounds pretty robust, only it assumes you convert all your files which sometimes isn’t the case … now, what’d be really nice is if Apple started supporting these container formats natively in QT instead of needing a rewrap … but thats just me pipe dreaming
