Can not get Vegas to record from a microphone
Posted by Joseph Dezordi on November 26, 2005 at 9:55 amfor some reason Vegas does not register input from the microphone
Jeremy Rochefort replied 20 years, 10 months ago 3 Members · 2 Replies -
Greg Noss
November 26, 2005 at 10:30 amJoseph,
You probably need to set your recording hardware in windows.
Right click the speaker(volume) icon in the task bar, click “adjust audio properties”, Click the “audio” tab, select your sound card from the drop down menu. There may only be one to select. Click “Volume” make sure the select check box under microphone is checked. Slide the volume slider up. That should do it.
Some sound cards Do Not support recording. I have an Avance AC97 in my lap top that works and I have never had a problem using any of the Creative Sound blaster cards. Good Luck.
Greg Noss
elementalfusionsi.com -
Jeremy Rochefort
November 26, 2005 at 12:01 pm
