Activity Forums Adobe Encore DVD Can not burn Bluray Discs? Error
  • Can not burn Bluray Discs? Error
    Posted by Rex Polanis on July 20, 2012 at 6:44 am
    I just upgraded to CS5.5 to CS6. I have never had this problem before. I keep trying to burn a Bluray using Encore CS6, however, I keep getting this maessage after the program tries to burn the Disc:
    “Bluray Error: “device error”, Code: “3”, Note “CreateStcSequence:Fail to write M2S file””
    Encore will burn the 8.22gb of 8.49gb to disc and then display the above message. I keep burning coasters, Grrr! How can I resolve this? Thank you.
    One man with courage makes a majority.
    Canon 7D
    Sony Vegas Pro 11
    Adobe CS6 Master Suite
    Hank Sorrick replied 14 years ago 3 Members · 4 Replies
  • Jessica Mantheiy
    July 20, 2012 at 11:31 am
    Encore CS6 gives me similar issues with a DVD. Canyoy burn an image file on the Blu-Ray and then use with Toast or Disk Utility to burn it?
    Jessica Muth
    Production Operations Manager
    Video Labs
    Rockville, MD
    301-217-0000
    jmuth@videolabs.net
  • Rex Polanis
    August 8, 2012 at 1:52 pm
    The only work around I have had success with is to use Encore CS5.5. I have been on the adobe boards and they keep telling me it’s either the discs or burner I am using but that can not be true because I am running 5.5 on the same machine (which by the way is a brand new computer I just built it in May with all new hardware) with the same discs and I have no problem. This is very annoying. I am surprised no one else it having the same issue.
    Canon 7D
    Sony Vegas Pro 11
  • Rex Polanis
    August 25, 2012 at 11:51 am
    How would I do that? I have never burned a Bluray image. I am on windows 7 64.
    Canon 7D
    Sony Vegas Pro 11
  • Hank Sorrick
    August 31, 2012 at 2:52 pm
    I am having the EXACT same issue. Read the same BS from Adobe. I do not want a work around. I am using iHBS112 2 drive. Again no problem burning the project in 5.5, but I should not have to!!!
