Activity Forums Apple Final Cut Pro Legacy Can new MacBook Pro handle HDV?
  • Can new MacBook Pro handle HDV?
    Posted by Brian Lindstrom on October 24, 2006 at 7:11 pm
    Hi:
    I see the new MacBook Pros are out today (please see specs below). I’m in the market for a new system to edit HDV on FCP. Can the MacBook Pro handle HDV (obviously with external hard drives)? I’m producing a very low-budget documentary and the possibility of saving about $600 on the monitor of a desktop system is appealing. My thinking here is that I would just use the screen of the laptop and wouldn’t need an external monitor.
    Brian
    17 inch MacBook Pro
    2.33 GHz Intel Core Duo
    1680 x 1050 pixels
    2 GB Memory
    160 GB Hard Drive
    8 x double layer super drive
    ATI Mobility Radeon X1600 graphics w/256 MB SDRAM
    George Loch replied 19 years, 11 months ago 5 Members · 4 Replies
  • Steven Gonzales
    October 24, 2006 at 7:40 pm
    If you bought a dual 2.0 tower w/ 2gb Ram and a 160gb hard drive, and a 20″ apple display, it would only be about $300 more than the 17″ powerbook, and much more expandable (you could put hard drives inside, which are cheaper than hard drives in external enclosures and maybe make up the difference.)
    Plus you could later add a video card such as AJA’s Kona 3 if you needed to finish the doc to another tape format.
  • Jeff Carpenter
    October 24, 2006 at 8:01 pm
    Short answer: Yes. It can handle it.
    You should either use Firewire 800 or get a SATA card for the express port for your external storage, however.
  • Ed Dooley
    October 24, 2006 at 8:02 pm
    I edit on my 17″ PB when I’m traveling, but it is no substitute for a real
    monitor. As a temporary solution until you can get a 20-24″ monitor,
    it would work fine for HDV. The data rate is like regular DV.
    Ed
  • George Loch
    October 25, 2006 at 6:32 am
    Unless you need the portability, the desktop will always be the better option in terms of money. The MacPro is $2,500 anda dell 20″ monitor run under $300 now.
    -gl
