Activity Forums Apple Final Cut Pro Legacy Can Multi-clip cause problems with re-linking media
  • Can Multi-clip cause problems with re-linking media
    Posted by Leah Attard on November 24, 2012 at 4:59 pm
    I’m running a project on FCP7.
    I have a full mirror copy on another drive, the copies are exact but the project won’t relink. This has only happened since I have used the multi-clip function to cut some material.
    Has anyone experienced this problem?
    Don’t Cry Yet
    Paul Levin replied 13 years, 9 months ago 2 Members · 1 Reply
  • Paul Levin
    November 25, 2012 at 10:08 pm
    There used to be a bug involving relinking multiclips, but I thought that was resolved in version 7. I’m in 7.0.3 and I relink multiclips all the time..
    one suggestion i have is to make sure the entire file-paths are exactly the same (including the drive name) then it shouldn’t need to be relinked at all. in theory.
    also, try collapsing your multiclips, then relinking. It’s not a solution per se, but if it works, then you know the problem is your multiclips.
