Activity Forums Apple Motion Can Motion do effects masks?
  • Can Motion do effects masks?
    Posted by Marc on August 21, 2005 at 4:10 pm
    Hello, everyone,
    I usually do all my post work in the node-based Digital Fusion where I can restrict the area affected by a certain effect (e.g. blur) by simply adding an effects mask to the node. This can be feathered, inverted etc. So far I have not been able to recreate this in Motion. I guess it’s simple, but I just can’t seem to get my head around working in layers instead of nodes. So, how do I do it (if it is at all possible)?
    Thanks for your help,
    Marc
    http://www.marc-hermann.de
    Marc replied 21 years ago 3 Members · 3 Replies
  • Morten
    August 21, 2005 at 8:39 pm
    The toolbar gives you access to square/circular or bezier masks. The masks can be feathered with up to 50 pixels – but it seems to work better with applying a blur to the mask. Check the manual for details…
    – No Parking Production –
    FCP 4.5, Dual G5, X-Raid
  • Jayson Steckler
    August 22, 2005 at 5:22 pm
    I haven’t found a way to only use a filter on a portion of an image (effect mask) but the work around is pretty simple.
    Place the footage over itself.
    apply the filter to the top most copy
    mask it to reveal the original unaffected copy underneath
    And FYI
    “The masks can be feathered with up to 50 pixels”
    The masks (and shapes) can be feathered from -1000 to 1000
    Hope that helps.
  • Marc
    August 29, 2005 at 11:43 pm
    Thanks for your help. I already thought of this work-around.
    But the beauty of Fusions effect masks is that feathering affects the strength of the effect, eg. going smoothly from unblurred to blurred.
    Ah, well, maybe I should file a feature request…
    Cheers,
    Marc
