Activity › Forums › AJA Video Systems › Can IO Capture to IMX in FCP 5
Posted by Devin Crane on June 30, 2005 at 1:44 pmI haven’t made the dive yet but was wondering if IO could capture from SDI 8 bit Uncompressed to IMX like it does to DV50 in FCP5?
Devin Crane replied 21 years, 1 month ago 2 Members · 3 Replies -
Bill Portune
June 30, 2005 at 3:32 pmHi Devin,
When I first loaded FCP5 I played around with the IMX codec and did digitize some footage via SDI, but I don’t remember how it worked. When I get to my office I will give it another try through the IO with the new driver (2.0) and let you know how it works.
Bill Portune
The Chesapeake GroupG5 DP 2G, 10.3.9, QT 7.0.1, 1.5GB RAM, FCP 5.0, Io (2.0), Kona2(1.1.1), UL4D, Huge U320R
Bill Portune
June 30, 2005 at 5:25 pmWorks just fine – all the realtime efx are functional too. FCP supplies a sequence setup, but AJA doesn’t supply a capture setting. You can duplicate/modify the DV50 setting, just change the frame size (to 720×486) and change the compressor to IMX50.
No promises, but it seemed to work fine for me.
Bill Portune
