Activity Forums Apple Motion Can image be changed after putting in behaviors
  • Can image be changed after putting in behaviors
    Posted by Terry Maloney on January 8, 2020 at 6:01 pm
    I want to have an image do all sorts of acrobatics (spin, move, zoom. jump, etc).
    I will export the work to my hard drive.
    Then there are several more objects I want to do the same acrobatics. In the final video – sometimes I’ll use one object and other times I will use a different object.
    Which way is more stable?
    1) make a copy of the Motion 5 project, open it, and then just change the object, then export that video.
    OR
    2) make a preset of the behaviors from the original, open up a new layer with a different object, and add the preset which has all the movements pre-set-up.
    Terry Maloney replied 6 years, 8 months ago 3 Members · 4 Replies
  • Doug Metz
    January 8, 2020 at 9:35 pm
    Another thought would be to put all of the images into a single Group, and apply the behaviors to the group. Then you could toggle each image in the group and export individually.
    Doug Metz
    Dalton Agency
  • Terry Maloney
    January 9, 2020 at 2:01 am
    wow, that’s slick, Doug.
    Thank you
  • Robin S. kurz
    January 9, 2020 at 10:49 am
    Simply drag whatever image onto the existing one until you see a hooked arrow and drop. Replaced.
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
    Youtube | Facebook
  • Terry Maloney
    January 9, 2020 at 8:09 pm
    Thanks Rob !
