Activity Forums VEGAS Pro Can i zoom or enlarge a corner of my video frame before renduring?
  • Can i zoom or enlarge a corner of my video frame before renduring?
    Posted by Glenn Rotar on July 2, 2012 at 9:26 pm
    Id like to zoom or enlarge a corner of my video frame before renduring so that after I burn it it will play full screen.
    Can Vegas do this?
    Graham Bernard replied 14 years, 2 months ago 2 Members · 4 Replies
  • Glenn Rotar
    July 2, 2012 at 10:48 pm
    Okay Ive discoverered the pan/crop function. Can it be programmed to to a gradual zoom out. So far ive had to split the video, set crop in each section but the switch from one frame to the next is an instant zoom out or a instant pan over .
  • Graham Bernard
    July 3, 2012 at 5:41 am
    [Glenn Rotar] ” Can it be programmed to to a gradual zoom out.”
    Yes, most certainly.
    Below the Pan/Crop window is a mini Timeline. You can place Key Frame markers to set where and how fast Zooms and Pans are executed. No need for splitting an Event.
    If you can’t see this mini Timeline, then move your mouse Cursor over one of the edges under the Pan/Crop Workspace. You should see the Mouse cursor changed into a Double Headed Arrow. Hold down the Mouse button and Drag Upwards. That should reveal the mini Timeline.
    Cheers
    Grazie
  • Glenn Rotar
    July 4, 2012 at 4:47 am
    yes thanks, it works great!
  • Graham Bernard
    July 4, 2012 at 6:18 am
    Good!
