Activity › Forums › Adobe Illustrator › Can I view corrupted ai files in adobe illustrator?
  • Can I view corrupted ai files in adobe illustrator?
    Posted by Agneta Karlsson on January 6, 2015 at 4:03 pm
    I save AI-illustrator file and the file was damaged. When you open (I tried different programs) receive the message type “PDF file format is having difficulties. The file is damaged and couldn`t be repaired”. Can I view corrupted ai files?
    Lance Bachmann replied 11 years, 8 months ago 3 Members · 2 Replies
  • Vincent Rosati
    January 6, 2015 at 4:59 pm
    I’m afraid you might be hosed 🙁
    Try opening the file with: Acrobat, Distiller, and Photoshop to see if anything can be recovered.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Lance Bachmann
    January 6, 2015 at 8:50 pm
    It depends on the percentage of file which gets corrupted. Their is a chance that half of file or 20-30% file data would get recovered.
