Activity Forums Apple Final Cut Pro Legacy can I use widescreen (anamorphic) footage with 4:3 footage in the same timeline in FCP
  • can I use widescreen (anamorphic) footage with 4:3 footage in the same timeline in FCP
    Posted by Todd George on August 2, 2006 at 7:35 pm
    Hello Everyone
    hope you are all staying cool
    I’m almost embarrassed to ask this but since I haven’t shot or worked with widescreen footage in several years (2001 to be exact) I need to ask
    ok here’s the situation:
    I’m working with footage I shot back in 2001 I shot it widescreen and I want to edit this footage into a sequence with regular 4:3 footage
    first of all I need to figure out what preset I capture the anamorphic footage with in FCP, I found the anamorphic dv preset and used that , the footage was widescreen in the log capture preview area but as I captured the footage it “squished” not sure if it will look that way when I put it on the time line
    assuming I captured the footage correctly, how do I get the footage to maintain it’s correct aspect ratio in a timeline when I want to edit in footage that shot 4:3 as well?
    I’m using fcp5.1.1 on a powermac g5 with a 2ghz processor and 2 gig of ram
    thanks in advance for any help
    Travis Ballstadt replied 20 years, 1 month ago 3 Members · 2 Replies
  • Jeremy Garchow
    August 2, 2006 at 10:05 pm
    Capture it in normal 4:3, and when you edit in to the timeline, change the aspect ratio to -33.33 under the distort property of the motion tab. This should give you a letterboxed image. If that’s what you want, leave it (that means the rest of your 4:3 footage will require a widescreen mask). If this isn’t what you want, you can then scale up the image so that it fills the 4:3 window and crop off the sides (kind of like a center cut).
    Make sense?
    Jeremy
  • Travis Ballstadt
    August 3, 2006 at 3:25 am
    Why not just capture it anamorphic and let FCP set it to letterbox in the 4×3?
    travis ballstadt
    http://www.thrillcateditorial.com
