Activity › Forums › Adobe After Effects › can i use the brightness value of a certain pixel in my comp in an expression
  • can i use the brightness value of a certain pixel in my comp in an expression
    Posted by Noizzz on July 7, 2006 at 1:32 pm
    gonna try to explain in english:
    can i use the brightness value of a certain pixel in my comp in an expression? is there an effect that uses a point controll and dispays the brightness of the pixel where it is located?
    Suppose i have a little red dot, and i put a wiggle on the position, is it possible to put an expression on its scale so that is grows when it “flyes” over lighter areas of the layer (or comp) underneath?
    Hope its clear what i want to say,
    Thanx
    Grtz
    NoiZ
    Mannyr replied 20 years, 2 months ago 5 Members · 5 Replies
  • Mylenium
    July 7, 2006 at 2:22 pm
    You need a color sampler utility such as Digital Anarchy provides it with their Anarchy Toolbox. AE does not have those functions natively.
    Mylenium
    [Pour Myl
  • Noizzz
    July 7, 2006 at 2:44 pm
    thanx, i will check the trial
  • Akiranakayama
    July 7, 2006 at 6:05 pm
    I was actually trying to do this last night in one of my comps. I want to rig up a tick-marked circle to rotate based on the average luminance of an image or image sequence. Or maybe just a pixel within that image. Is there a way to derive the luminance data so that it can be used (in an array I’m assuming?)??????
  • Majorasshole
    July 9, 2006 at 11:06 pm
    can you use displace to fake it? the color of a pixel effects how much it displaces
  • Mannyr
    July 23, 2006 at 7:08 am
    Did you figure out how to extract the average luminance of an image?
    I have a similar situation where I have a black and white “blob” that pulsates and I want to link the pulsation to an effect on another image in another layer. I figured that extracting the average luminance of the blob layer and generating keyframes from that could drive the other effect. But I haven’t figured out how to do it yet.
    Any suggestions?
