Activity › Forums › Adobe After Effects Expressions › Can i use something similar to “app.settings.haveSetting(sectionName, keyName)” in expressions?
  • Can i use something similar to “app.settings.haveSetting(sectionName, keyName)” in expressions?
    Posted by Andrei Popa on June 18, 2018 at 11:42 am
    What i am trying to do is create some “piracy-proof” .aep template. I would like to write something inside the expressions contained in my project that will not work unless you run a script in which you write a serial code. The script would then save the keyName settings in the app which will enable the expressions to work. I don’t necesarily want to use haveSettings in expressions, but could not think about other solution.
    Andrei
    My Envato portfolio.
    Andrei Popa replied 8 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
