Activity Forums VEGAS Pro Can I use s-video out as preview monitor?
  • Can I use s-video out as preview monitor?
    Posted by Willie Bobo on December 26, 2008 at 11:40 pm
    I’m running 8.1 on Vista 64 and I have a dual monitor card with a 4 pin s-video out (ati radeon hd 2400).
    Before I buy an s-video to RCA adapter I need to know if I can run my dual monitors AND run the s-video to a TV and use it as my preview. In other words can I just select Windows secondary monitor in V8.1 and enable this function? May be a dumb question but I’m feeling pretty dumb lately.
    Randy
    Willie Bobo replied 17 years, 8 months ago 2 Members · 4 Replies
  • John Rofrano
    December 27, 2008 at 1:42 am
    Not a dumb question at all and the answer depends on your graphics card. Most dual-head cards are limited to two simultaneous signals even though they have more outputs. I believe what you will find is that your graphics card will drive the secondary monitor OR the S-Video out but NOT both at the same time.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Willie Bobo
    December 27, 2008 at 4:11 pm
    Thanks JR,
    I’ve googled all morning (for ATI RADEON HD2400 xt manual users guide review) but can’t determine if it has the capability to do both or not so I guess I’ll just have to buy the cable to find out.
    For the last few years I’ve been using my JVC SR-VS30 deck for the preview but Vista 64 is complaining it can’t find drivers for it…. but if V8.1 has the capability to utilize the S-video out along with the dual monitor (if the card is capable) then maybe I should go that route since I don’t use the deck for capture anymore (I capture through the camera due to the deck pixelating frames occasionally.)
    Thanks again Jr,
    Randy
  • John Rofrano
    December 27, 2008 at 4:24 pm
    Not sure why you would have to buy the cable to find out. Try going into the control panel for your graphics card and enable the S-Video output. If your secondary display goes blank (like mine did), you can’t have both on at once. If the secondary stays on, chances are you will be OK. (then buy the cable)
    ~jr
  • Willie Bobo
    December 27, 2008 at 4:49 pm
    Thanks JR,
    I will definitely try that once I get the DVI to VGA adaptor I have on order (should be Monday).
    Thanks again,
    Randy
