Activity › Forums › AJA Video Systems › can I use media I captured using cinewave on a new mac, fcp and kona 3 card?
  • can I use media I captured using cinewave on a new mac, fcp and kona 3 card?
    Posted by Lee on January 23, 2006 at 3:22 pm
    Hi Guys
    I’ve captured over 200 hours of footage using my cinewave system using codec DVPAL, but some other tapes were using TARGA YUV codec.
    I don’t want to capture it all over again!
    could I use the these files if I moved my drives from my old cinewave system to my new knoa + g5?
    Paul
    Jeremy Garchow replied 20 years, 8 months ago 3 Members · 4 Replies
  • Walter Biscardi
    January 23, 2006 at 3:29 pm
    Set up a Sequence using the 2Vuy codec and you should be good to go.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Lee
    January 23, 2006 at 3:54 pm
    Hi walter
    can you clarify
    set this up in the kona software and then I should be able to read the files?
    Or do I set this up in the cinewave and re capture?
    Paul
  • Walter Biscardi
    January 23, 2006 at 4:18 pm
    In the Final Cut Pro Audio / Video Settings or the Sequence Settings.
    Set up an AJA 8 or 10bit SD Sequence Setting, but then change codec to 2Vuy. You do this with your AJA system. I’ve never had to do this but that’s what the codec does. It’s an old Blackmagic codec that you can use to playback CineWave files in an AJA timeline.
    Folks who have tried this have reported success on this forum using that setting to play back the CineWave files. I’ve never had to use any of my old CineWave stuff with the Konas so I don’t have first-hand experience with it.
  • Jeremy Garchow
    January 23, 2006 at 4:27 pm
    What Walter says, but you’ll have to recapture the PAl dv25 files. Kona does not handle different codecs in the same timeline as Cinewave. You need to either recapture your pal dv25 as 2Vuy, or your targa as pal dv25 and set up your timeline accordingly. If you decide to keep everything dv25, then set your timeline to that, if you decide to do 8 bit uncompressed, then you must set your timeline to that.
    Jeremy
