Activity Forums Adobe After Effects Can I use math to program the pen tool path for an object?
  • Can I use math to program the pen tool path for an object?
    Posted by Mark Palmer on February 29, 2020 at 7:55 pm
    Instead of manually using the pen tool to create anchor points for a path that an object can follow, can I input a file or use a mathematical equation that sets the anchor paths to the numbers in the file? That way I can make paths that relate to complex equations without having to do it all by hand.
    Mark Palmer replied 6 years, 5 months ago 3 Members · 3 Replies
  • Cassius Marques
    March 2, 2020 at 1:21 pm
    That, if doable, should be a lot of trouble, perhaps do that in math software that can export vector? Then import into AE.
    After Effects is a compositor in its essence, I’m guessing you’d have better luck finding a plugin/macro/script that does that for illustrator or Corel Draw or something alike.
    Cassius Marques
    http://www.zapfilmes.com
  • Walter Soyka
    March 2, 2020 at 2:31 pm
    The path property is now accessible to expressions, so yes, you could use outside data to draw a path. Here’s some documentation:
    https://expressions.aenhancers.com/path-property.html
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Mark Palmer
    March 5, 2020 at 5:09 pm
    Thank you, I’ll give it a try!
