Activity Forums Apple Final Cut Pro Legacy Can I use FCP 4.5 & 5.0 on the same system?
  • Can I use FCP 4.5 & 5.0 on the same system?
    Posted by Reed Brown on September 23, 2005 at 2:53 am
    I know once a 4.5 project has become a 5.0 project, you can’t go back to 4.5. However, I have a client who is using 4.5 and wants to keep their projects in 4.5. I just got 5.0 and want to load it WITHOUT affecting this client’s 4.5 workflow. Does anyone know if I load FCP 5.0 onto my system, can I still open 4.5 projects and KEEP THEM AS 4.5 PROJECTS? Seems to me, even with 5.0 loaded, if I open FCP 4.5 first, then open the 4.5 project, work, and save it within 4.5, I’ll be OK. In other words, it will remain a 4.5 project. Or will things get too messy having 4.5 & 5.0 on the system?
    Thanks for your help.
    Jeremy Garchow replied 20 years, 11 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    September 23, 2005 at 3:09 am
    Get yourself another internal drive and install tiger & FCP5 on that, That way you will have a working 4.5 and a working fcp5 on completely separate drives. That way you will boot into whatever system you need. Trust me, it’ll save you so many headaches. Do not attempt to install both versions on one drive.
    G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
    ATTO 42XS <> Huge Systems 1.25 TB 4105 Fibre
  • Matt Murray
    September 23, 2005 at 10:49 am
    Hmmmm, not really true, as I have FCP 3, 4 and 5 on the same drive.
    BEFORE you install FCP 5, rename the FCP 4.5 HD, in my case I did just that, named it 4.5 HD, and all is well.
    Matt Murray
    Lineside Productions
    Wellington, FL
    https://www.edgesportfishing.com
    Florida Sailfish videos, pictures and more
    Mac OS X 10.4.1 , QT 7.0 Dual 2.5 GHZ, 4 gigs RAM, 23″ HD display, JVC BR-3000 deck, 5 120 gig LaCie Firewire Drives, JVC 17″ H1700 NTSC monitor, FCP HD 5, DVDSP 4, Compressor 2.0, Motion 2.0
    Soundtrack Pro 1
  • Jeremy Garchow
    September 23, 2005 at 2:56 pm
    Kudos. Glad you got that working. If you have capture hardware this could pose problems as certain hardware drivers require certain versions of quicktime and OSX.
    Reed, sounds like it’s up to you. Keeping the systems and version separate has been recommended up and down this forum and others, but do what you wanna.
