Activity › Forums › Panasonic Cameras › Can I use an FS-100 to record downconverted HDX900 Footage (while rec HD to tape)?
  • Can I use an FS-100 to record downconverted HDX900 Footage (while rec HD to tape)?
    Posted by Brian Broz on November 29, 2006 at 9:32 pm
    I’m wondering if I can shoot 720P/60 to tape and simultaneously record NTSC 480/60i SD to the Firestore?
    Of course using the camera’s firewire output. Has anyone tried this? Ideally with the same timecode in SD as HD?
    A customer is wanting to record standard def for offline for a tv series, as they have several edit stations but only 1 HD1400 deck.
    Thanks for any help or suggestions.
    Regards,
    Brian Broz
    LLSR.com
    Tony replied 19 years, 10 months ago 3 Members · 2 Replies
  • Peter Steinman
    November 30, 2006 at 5:22 am
    There is no down conversion on firewire output on the HDX900. What you shoot is what you get out that tap.
  • Tony
    December 1, 2006 at 5:05 am
    why do this when the file size of the native dvcproHD codec is small enough to deal with easily in FCP or Avid.
    Tony Salgado
