Activity › Forums › Adobe After Effects › can I use a proxy for a psd imported as a comp?
Posted by Arlene Golant on May 22, 2005 at 6:13 pmI’ve searched the forum and can’t find an answer. Using 6.5. I imported 4 or 5 large psd’s already.
Anyway to substitue proxies. All psd’s have many layers.
thanks in advance.David Johnson replied 21 years, 4 months ago 2 Members · 5 Replies -
David Johnson
May 22, 2005 at 7:49 pmSure…just move to the frame in the PSD comp where you want your proxy to begin, then right click it in the project window for the Create Proxy option.
Arlene Golant
May 22, 2005 at 8:03 pmSorry. I’m either not being clear, or I’m just not getting this. I’ve imported psd’s as comps. Those comps are, in turn, going into other comps. When I select the psd comp (not the layered psd file) in the project window and select ‘select proxy’ I browse to a 72dpi version of the psd, but there is no indication in the project window that a proxy is being used. (when I do the same for a flattened bitmap, I get the black square next to it).
Where’s my mistake here?
David Johnson
May 24, 2005 at 2:07 amI just did exactly what you described and AE did recognize the proxy I chose and showed the black box. I’m on Windows AE 5.5 PB right now, but use both Mac and Windows machines with AE 6.5 PB at work and haven’t had a problem with proxies on any of them. Sorry I couldn’t help.
Arlene Golant
May 24, 2005 at 2:40 amWow. Weird. Thank you for trying that. Do you suppose it’s a Mac thing?
David Johnson
May 24, 2005 at 3:07 amI doubt it, but I suppose it could be. I use proxies on Macs too, although I don’t recall specifically whether I’ve proxied any PSD comps lately.
